djay2 Spotify Missing
not long ago i used djay2 with my spotify account to play music between sets during a gig but now spotify is nowhere to be found in the app? Was it removed and now only a djay pro exclusive?? That’s pretty crappy…
thanks, i figured it out after a bit.
Fred
you can access the Spotify library via selecting a track, now click on the iTunes sign in oder to change the library you want to select tracks off. Now select the Spotify library and log into your Spotify premium account.
