Djay2 and Wego3 suggestions/questions (not necessarily just with Wego3)
There are some things that I thought would be useful but maybe I’m missing something:
- “Slip” only works when you’re “playing” the waveform, but can it be used if you’re looping or scratching?
- On a Wego3, you must engage the Effect on and button and turn the platter to raise or lower the effect. If you turn off the effect using the button, then the next time you use the effect, it will be at maximum. Is there way or preference that when you engage the FX, it starts at a default value (ideally, which could also be user configured).
- A song’s Key and BPM get analyzed when loaded, but is there a way to force analyze your library or playlists?
Thanks.
