DjayPro Windows and Mixtour + Neon
Will djay Pro (Windows) will work when 2 controlers Reloop Mixtour and Reloop Neon are connected into 2 separate USB ports (there is unofficial mapping for Neon)
yes you can connect as many midi controllers to your setup as you want :slight_smile:
There has been no update on the WIndows version in about 16 months, so honestly, don’t think you will ever any update on that question.
Lukas, thanks for your replay.
To further clarify, I am asking about working with them at the same time (i.e: use pads for CUE /LOOP/FX control from NEON, while rest handle by Mixtour)
…any update?
