I Just bought the dJ control Jogvision, I’m using it with Djay Pro (not pro 2) on a Mac Book Pro running 10.15.4.
The peaking lights don’t work?
None of the Beat syncing controls works?
The “Vinyl” button works in reverse (on is off), this effects the jog wheels!
The Air controls also work in reverse (the lower your hand, the less effect)?
I could go on and on.
I’ve downloaded all the latest available patches, still just not working properly? Has anyone else come across this and successfully solved it?
