Device model Hercules DJ Control Ultra, Xiaomi Pad 7 Pro and Nothing Phone 2A:
- Version of operating system Android,Windows
- Version of djay : Latest
- Hardware/controllers used Hercules DJ control Ultra, Pioneer FLX4 and Pioneer RX3
I have searched however the information seems fragmented or quite old. I wondered if you could possibly detail any further plans around the android ecosystem and Djay. Points below
Android future integration with CUE points sync across other android devices and windows? Sharing my actual music files is acceptable using a program like syncthing however no import or sync with CUE points across android and windows devices is limiting. Whether this is android to android or from my windows desktop.
MIDI mapping in relation to the Hercules DJ control Ultra. For example id like to setup being able to skip inside a track while setting cue points from a workflow perspective at certain bars (8,16) for example. I am not sure if keyboard mappings are exposed to help with this either, any future plans here?
Android and Playlist management. Hopefully you may be able to let me know what is the future here particularly where android is concerned without using third party apps. Currently I’m using symfonium to create and manage playlists including smart ones, which I can export to Djay on the same device. But Thier is obvious room for improvement.
Thanks for continuing to make a great product. I really enjoy where Djay is heading!
