Hola alguien sabe por qué mi PC Windows no reconoce dispositivo dj control ultra mix por medio del cable hace unos días funcionaba y ahora sale con un logo amarillo? Cuál es la solución
Si a Actualice Windows 11 25h2
ENGLISH TRANSLATION:
Hi Does anyone know why my Windows PC isn’t recognizing my DJ Control Ultra Mix device via cable? It was working a few days ago, and now it shows a yellow logo. What’s the solution?
Easiest way to resolve the MIDI issues until Microsoft rolls out another update soon is to just do this very quick and easy workaround:
Press Win + R, type services.msc, and press Enter. Find Windows MIDI Service. R/H click it and select Properties. Change “Startup type” to Automatic. Click Apply and Start. Then everytime you start your computer it’ll make sure MIDI starts as normal. No need to uninstal any of the updates.
And for reference KB5079473 is also a cause of the issues as well as the 3 other KB updates on the Algoriddim troubleshooting page.
Hello everyone, we released a supplemental update to Windows djay 5.6.4 on April 10 which should fix the issue where MIDI controllers are not detected. We added a small workaround which should ensure that the Windows MIDI Service is started on app launch. I hope that helps!
