Djcontrol Mix Ultra won’t connect to iPad using Bluetooth
  • Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro (11-inch) (4th generation)
  • Version of operating system *. IOS 18.3
  • Version of djay (e.g. 5.1.2). 5.2.10
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): DjControl Mix Ultra
Summary of the issue:
iPad will not connect to controller using Bluetooth
I have forced restart iPad several times. Nothing works
But the device will connect to my iPhone & MacBook Pro
How to reproduce the issue:
I reinstalled DJay on my iPad and when I opened Djay it ask for permission to use Bluetooth devices. My problem is fixed.:folded_hands:
Good to hear you sorted it out @Five-0. Thanks for the follow up.
