DJM S11 and recording issue
  • Device model: DJM S11 CDJ 3000
  • Version of operating system: Macos
  • Version of djay: 5
  • Hardware/controllers used: DJM S11 and CDJ 3000
Hi all, I am wondering how should I route the audio for recording?
Everything else is fine only recording no audio…
Hi @mrtbdmn, if you are using the Record function within djay, there is no need to route the audio. This is handled internally and recorded to your Mac hard drive. You can find the recordings here:
Hello Slak,
Yes I found the folder and the file, but there is no sound recorded. When I changed the audio routing, I found out that the level bar rises as the song played, but one of the fader doesnt work. If I set the audio recording to ch 1-2 it doesnt allow me.
As you have DJM-S11… why you don’t record using “Booth Output” or “Master RCA”?
Much easier option to record the audio than figuring out how to route audio internally on mac.
Also note that the “Booth output” doesn’t know if you are playing audio from streaming services.
Something like Tascam DR-40X | Portable Four-Track Digital Audio Recorder and USB Audio Interface ?
Doesn’t even cost too much
Thanks for the tip @dj_romy_fi. This is exactly what I do to record my sets. Except I use the Sony PX470. Ideally, you want to connect it to a “record out” on your hardware so the recorded volume isn’t altered by the master volume on the hardware. Booth out also works if you set the booth volume and leave it there during your recording.
Okay I will try using external recorder thank you guys
Do you have a DAW or something like Audacity installed?
With the RANE72 you can record channel 5-6 from the audio interface and get your master signal straight into a DAW.
(you can also record ch1-2 and so on . . . for single channel pre or post fader)
Never used the s11, but as it is also an audio interface, it should have similar capabilities.
A bit of testing or googling to find what channel the master out is on, should be easier than getting a hardware recorder.
Slak_Jaw for me the Record function within djay gives me a file with no sound.
Any suggestion?
spiro Which settings do you use with Audacity?
Thank you!
Hi @JP369, it depends on the mode you’re using your mixer in. If you’re using External Mixer Mode in djay, then you would need to configure “Recording Input” in the audio setup in order to record, which requires the mixer to support “REC OUT” (which they usually do, and this is done automatic for any of the mixers we support natively). With this set up, djay will record the audio signal coming back from the mixer/controller.
Hi, thanks for your reply.
I am using an external mixer (DJM-S11) and for the “Recording Input” I’ve selected the DJM-S11. Then I have channels options. If I select Ch 7-8, I can only record the audio coming from the Deck 1. If I select Ch 9-10, I can only record the audio coming from the Deck 2.
Do you have any idea why? :thinking: :sweat_smile:
Slak_Jaw Thank you, finally I have found the problem and now it is recording. :wink::+1:
You’re welcome @JP369. Happy to help!
By the way, I’ve discovered that anytime I launch djpro, the recording never works (the settings are correct). But, for whatever reason, in the moment I launch the Pioneer Settings app, the recording start to work. Again, I have no idea why, but if I don’t open the Pioneer Settings app after starting djpro, the recording is not working.
I want to say it here, it might be helpful for someone else…
Thanks for sharing @JP369
Slak_Jaw You’re very welcome! :wink:
I have same problem, recording without audio sound.
