DJM-S7 Documentation
Right now i’m using djay on an iPad, external soundcard and a Pioneer DJM-450. It works great, but I’m looking into the Pioneer DJM-S7.
I read and see the DJM-S7 is play and play compatible, but I am curious about the pads and the pads the effect paddles and the overall mapping.
Is there any documentation on the default mapping available? Or has anyone got experience with a DJM-S7 in conjunction with djay on an iPad?
Hi @Kikeon,
The DJM-S7 is plug-and-play compatible with iOS and macOS and has been pre-mapped for djay including the performance pads!
Should you encounter any difficulties, we encourage you to reach back out to us so that we may look into the issue further.
