I know that the DVS feature using the Pioneer DJM-S9 is only listed for Mac.
Is there any plan to make it work in iOS? Or is there a workaround like the one with the S11?
Thanks in advance!
Thanks in advance!
The S9 is not class compliant, and thus not working without a driver. On iOs there is no way install drivers. So it’s actually Apple and Pioneer you should be asking about this. Apple is not taking another approach, and the S9 is succeeded by the S11 and the S7, so no chance they will update the firmware. It is what it is, unfortunately.
