Algorithmic DJ Pro on aiOS sees my DJM750 MK2 as a midi device, but will not let me use it as an audio device. Is there a solution for this?
DJM750, and DJM450 for that matter are not class complient audio devices. iOS only works with class compliant devices. Maybe this can be solved with a firmware update, but this is something only Pioneer can do.
I use the DJM450 with an external class compliant soundcard.
I’m using it with the audio 10 right now. I was just curious cause all four channels of my 750 are addressible on other iPad apps.
Hi @Myalteredsoul,
Thanks for posting to the community!
As @Kikeon pointed out, the DJM750 MK2 is not class compliant at this time.
Feel free to share your feedback with Pioneer as well regarding this matter.
Have a great day!
Thank you. Dropped the question on their forums. With their app coming out soon, we can only hope they wouldn’t limit its use to just battle mixers and budget controllers.
