As your document describes in 5.4.1 sometimes djpro2 will fail to detect the bpm correctly.
I have created smart playlists based on the bpm like
85-89, 90-94,… and the last one is >150 bpm.
I have found songs on the 85-89 bpm smart playlist
as instructed hitted the “Half/Double BPM”
the BPM value will be doubled
The song will be on the “85-89 bpm smart playlist” not visible in the correct one i.e “>150 bpm”
Tested on DJ pro 2.0.1 & 2.0.2
Lukas_E
#2
we are sorry to hear that.
Is this still the case after closing and reopening djay Pro 2?
Lukas_E
#3
can you send us exemplary screenshots of the playlists with the filtering and the displayed BPM value?
Thank you in advance.
Hi Romy,
we are working on the fix for this issue.
Sorry for the inconvenience and thank you for pointing this out.
Yes…
The closing-reopening won’t help.
Also checked if the actual file contained data in BPM field.
Cleared it and no change the song still in the wrong smartlist.
Good to know that fix is on the way
