Nubium
January 22, 2025, 2:08pm
1
Hi all,
I have an iPad Pro 11 inch , 4th Generation, 256 gb. Using it with Mixon 8.
Sometimes I’m experiencing a little bit of lag after for example, four hours of DJing, but maybe this is just a problem with the app.
So my question is mainly to the staff of the app running of the app work better if I got the latest generation of MacBook Pro with the M4 chip?
Kikeon
January 23, 2025, 10:22am
2
I have an iPad Air 4th gen 2020, DJAY (and most other apps) still run fine. Even using DVS.
Are you doing something special with it that i’m not doing that’s eating up resources?
Nubium
January 23, 2025, 10:57am
3
Hello, thanks for your answer. Could be stems.
Kikeon
January 23, 2025, 11:24am
4
i’m using just 2 tracks, but also use stems and effects etc.
Nubium
January 23, 2025, 11:38am
5
In that case, maybe I’ll just upgrade to a larger screen. Thanks for your info. I also watched a video saying there’s not that much difference between the M2 and the M4 chip as the M2 is just so powerful. We don’t need the M4.
M2 is more than enough for DJAY, stems, FX and whatever.
Like @Kikeon mentioned; be sure to disable the stuff you don’t need. There’s a thread floating around here somewhere with tips and tricks.
