Hi, i want to buy a pair of cdj 1000 mk3s and a djm 700
But i also want to use them with my laptop, so i want to buy a rane serato interface
Will any rane serato box work with Djay Pro for mac?
Thanks a lot!
Hi Hubert,
thank you for your mail. Do you also want to use Turntables?
Your setup with the DJM and the two CDJs is natively supported.
@Hubert Bertrand
I have nearly the same setup!
Do you got it to work? If you do then please share what you have done to make it work! I would pay you for that xD Really want it to work!
I have 2 1000mk3 and a DJM 450 Mixer…
