Does Allen&Heath K2 Midi controller is supported?
I can not find the A&H K2 in the Algoriddim’s supported mixer/controller list, but on A&H website K2 is listed like that. My question is, does K2 is supported Midi controller device for iOS DJay Pro or not?
The Xone K2 is compatible with djay Pro. You can use the MIDI Functions and Audio Interface. BUT, you will have to map the controller yourself. There is no midi mapping included in djay Pro.
Notes:
Beatport DJ has a template that might be a good starting for mapping the Xone K2 in djay Pro.
Thanks Michael, thats fine, that wouldn’t be problem, I will have use K2 with Xone 96.
