Does Djay Pro running on an IPad Pro 2018 work with a DDJ 1000?
I mean is it completely supported? Every feature works?
I’ve been using the reloop Beatpad 2 but I would like to upgrade to a 4 deck controller. One that I could also connect my 2 analog turn tables, and seeing how I read such positive feedback regarding the DDJ 1000, I would like to use that.
Thx Lukas, hoffentlich kommt es bald!
Hi Andi,
The DDJ 1000 is not natively supported by djay for iOS at the moment.
I added your request internally to our user request list.
You can find all supported djay for iOS controllers on our hardware page:
https://www.algoriddim.com/hardware#ios
Hi Andi,
Are there any plans to support the DDJ-1000 in the near future? The djay pro app on an iPad is far superior experience than using rekordbox on a laptop. Please make it happen.
Thank you!
