Does it work, Mac+Djay+OBS=Twitch No external audio or controller?
Does it work?
Only Mac+Djay+OBS=Twitch No external audio or controller maping ect… Nothing more.:thinking:
I’d really appreciate if there would be any info given!
I’m not asking about DRM or Spotify integration… Neither Apple Music
Thanks.
The problem with a direct path from Djay to OBS is that it is not possible to tap the signal from the internal output.
You need a “virtual sound card” such as
This sends the signal from DJay to an output of the virtual card and can then be picked up by OBS at an input of the virtual card.
This is the easiest way.
VirtualDJ has a built in broadcast option to stream directly to Twitch and other services, either with just audio or audio+ video. No OBS required.
You can also use the “Audio Output Capture” option in OBS. This should also work with DJay.
Been trying to live streamin from djpro via OBS no sound coming out , any help appreciated Thanks !!!
