Does my ideal controller exist?
Unfortunately not even USB Audio/MIDI Class Compliant for main I/Os. I would not recommend it.
it is what i said. It covers everything the OP requested, but is not compliant with DJay
I bought the ns4fx controller, the sound and connections are fine but the quality of the faders is terrible, after 6 months of use the fader on deck 2 went crazy and the one on deck 1 sometimes doesn’t work
Thanks for sharing @jenoux. Have you contacted Numark Support or the vendor you purchased it from?
Yes, Numark recommended me a procedure to clean the faders but it didn’t solve the problem, in the end I returned the console to Amazon and now I don’t know whether to buy the NS4FX again or another more reliable one.
I see. Thanks for the follow up.
