Does Neural Mix Pro also contain the new Neural Mix 2.0 tech with Audioshake?
Hi everyone,
Anyone happen to know if the new neural mix tech with audio shake has been put into the Neural Mix Pro standalone product?
Game changer if it has. I’m so impressed with the sound quality and have some serious bootlegs on the horizon if it is!
Cheers
When you say Neural Mix Standalone product. Are you referring to djay pro AI apps for iPhone, iPad MacBooks?
He’s more likely referring to this: Neural Mix™ Pro
Yeah, Neural Mix Pro - their standalone stem separation product.
@Mrbigmouthbeats these are separate pieces of software. Only djay Pro for macOS and iOS has been updated to 5.0 with Neural Mix 2.0.
