Does the Gemini CDJ-700 work with djay Pro? If so, how good are the midi mappings
I am looking to buy a Gemini CDJ-700 as an upgrade to my Pioneer CDJ-800 MK1s. The reason I chose the CDJ-700, is because I was looking for a low-cost CDJ that is compatible with djay Pro. The CDJ-700 supports MIDI control, but I want to know how well the CDJ-700’s MIDI works with djay Pro.
Anyone have success with a Gemini MDJ-500 (cd-less cdj-like midi controller)?
Technology is moving away from cd based controllers .
What is the advantage of the CDJ-700 vs CDJ-800 ?
All natively supported MIDI controllers (djay Pro for Mac and Windows)
To use a DJ MIDI controller with djay Pro for Mac or Windows, simply plug the device into your Mac or PC (before or while the app is running). djay Pro will detect the controller and automatically pre-map all functionality, allowing you to start using the controller right away.
And of course you can easily edit the mapping yourself and customize the controller for your demands if your controller/midi device is not listed.
Pioneer CDJ-TOUR1*
Pioneer CDJ-2000NXS2*
Pioneer CDJ-2000NXS*
Pioneer CDJ-900NXS*
Pioneer CDJ-2000*
Pioneer CDJ-900*
Pioneer CDJ-850*
Pioneer CDJ-400*
Pioneer CDJ-350*
Pioneer XDJ-1000*
Pioneer XDJ-700*
Pioneer DDJ-RX*
Pioneer DDJ-RR*
Pioneer DDJ-RB*
Pioneer DDJ-SZ2*
Pioneer DDJ-SZ*
Pioneer DDJ-SX2
Pioneer DDJ-SX
Pioneer DDJ-SR
Pioneer DDJ-SB2
Pioneer DDJ-SB
Pioneer DDJ-SP1
Pioneer DDJ-WeGO4
Pioneer DDJ-WeGO3
Pioneer DDJ-WeGO2
Pioneer DDJ-WeGO
Pioneer DDJ-ERGO
Numark iDJ Live II
Numark Mixtrack Platinum
Numark Mixtrack 3
Numark Mixtrack Pro 3
Numark Mixtrack II
Numark Mixtrack Pro II
Numark Mixtrack
Numark Mixtrack Pro
Numark Mixdeck Quad
Numark Mixtrack Quad
Numark Mixtrack Edge
Numark NS6*
Numark DJ2GO
Numark Total Control
Numark Omni Control
Numark Stealth Control
Reloop MIXON 4
Reloop MIXTOUR
Reloop Beatpad 2
Reloop Beatpad
Reloop Terminal Mix 2
Reloop Terminal Mix 4
Reloop Beatmix
Reloop Mixage IE
Reloop Digital Jockey IE2
Denon MCX8000*
Denon MC7000*
Denon MC6000MK2
Denon MC6000
Denon MC4000
Denon MC2000
Denon DN-SC2000
Casio XW-J1
Vestax Spin
Vestax Spin2
Vestax VCI-100
Vestax VCI-100MKII
Vestax VCI-300
Vestax VCI-300MKII
Vestax VCI-400
Vestax VCM-100
Hercules DJConsole Rmx2*
Hercules DJControl Instinct
Hercules DJControl AIR+,
Hercules DJ Control Air
Hercules DJ 4Set*
Hercules DJ Console 4-Mx
Hercules DJ Console Mk2*
Hercules DJ Console Mk4*
Hercules DJ Console Rmx
Hercules DJ Control MP3 e2
Hercules DJ Control Steel
Ion Discover DJ
Novation Dicer*
M-Audio X-Session Pro
* currently not supported on Windows
I am looking for a MIDI controller that is like a traditional CDJ or turntable, but is not a single unit. I want to be able to use two MIDI controllers with my mixer
