Im looking at buying the Griffin USB audio interface and need to know if it works the same as a splitter cable or if it puts a stereo signal out to both the headphones and the main out
Should work.
http://help.algoriddim.com/customer/p…
I’m wondering if you could use 2 of these with a hub and skip the iPad’s headphone output.
Hi Warren!
Would two of these and a hub work?
Hi Warren!
Any idea yet?
Hi Luke,
Yes, the output will then be in stereo for both Main and Pre-cueing channel(s).
Good question, I’ll check it out and get back to you.
