Does the MAYA44 USB Audio Interface work with djay?
  • Device model: Oppo Pad Air
  • Version of operating system: Android 13
  • Version of djay: 5.2.10
  • Hardware/controllers used: MAYA44 USB Audio Interface
Hi, does anyone know if this 4 channel audio interface will work with djay? https://www.esi-audio.com/products/maya44usb+/
Sometimes I just want to take the tablet to use for requests that I don’t have in my library and do my main set on my Pioneer CD mixers. But when I use a splitter cable so I can use pre-cue the sound quality degrades a lot in mono so I was wondering if this MAYA44 4 channel audio interface will work so then I can use 2 channels for main out and 2 channels for headphones.
I have a Pioneer WeGo 4 controller which works fine but I don’t always want to use it, sometimes I just need the tablet on its own.
Any info on this @Slak_Jaw
Why not try it? You list the tablet, the interface and the software - plug it in and see.
It supports Core Audio so it is class compliant.
Like @PKtheDJ wrote try it but it think you can’t right now cause you wanna make sure before you buy it right? :wink:
Sorry I just realized you are using android :smiling_face:
What’s an Oppo pad air? :joy:
I thought you meant iPad Air
I don’t know if it will work with your android device so I would reconsider this discontinued product that the manufacturer mentions everything except android. But hey it looks seriously discounted so you can take a chance
I would but I’ve not brought the audio interface yet, was trying to find out if it would work before buying it in case it doesn’t work.
Yes spot on I’m trying to find out if it will work before buying it!
The Oppo Pad Air is kind of a iPad copy by a chinese company called Oppo :joy:
It’s really good to be fair, I’ve tried lots of different tablets by Samsung and Lenovo etc. and none of them would work properly with a controller. They either had distorted audio or the pre-cue didn’t work. Then I read online about these Oppo tablets being good with audio so thought I’d give it a go and it works perfectly!
The chinese are getting really good at making (copying) stuff now :joy:
Yeah I might just have to take a chance and buy it and see… unless algoriddim can give a answer on it.
It’s really cheap by looking at the link you posted. It wouldn’t be a loss really.
In that case, you should not have stated…
Final decision is yours, but as there’s no mention of use with Android anywhere on the ESI site, it seems unlikely.
Hi @djsmoothe, sorry I can’t be of more help here. We do not have that device to test. I recommend that you reach out to the manufacturer support channel and ask them if it will work with Android tablets.
Hi djsmoothe
My name is steve
Can i have more infos about your oppo pad air ?
Are you able to cue and keep it in normal stereo or you have to switch to mono
I plan to buy a tablet along with my ddj flx4
And the reason i’m asking is that i use my gakaxy s20 plus with the flx4 it s realy good i did few gig with it but i want bigger screen an maybe be better !!
Hi Steve,
Yes the oppo pad air works properly to cue and have the main out in stereo when using my ddj wego4 controller, so it should would fine with your ddj flx4 too as this replaced the wego4 and ddj 400.
Its a great tablet for DJing I use it every week and its never gone wrong at a gig yet. Just keep it purely for music and don’t install loads of other apps that could cause it to slow down or have issues.
It’s not as powerful as your galaxy s20 plus, but it runs the djay app fine.
Oh thank you very much and how much ram do you have first an second on my phone i do my playlist in my samsung music player and export it and it’s automatically in the music folder of the phone wich is recognize by djay (awsome) do you know if there is an app or maybe samsung music player can install on the oppo pad air (if it’s not too much to ask)
And… yes the pad is only for music !!!
Sorry for the late reply I didn’t realize you had asked another question!
It has 4GB Ram and I use a app called Simple Music Player to create playlist in which are recognized by djay.
