HI, please add a feature when you get out of a playlist and come back to it, the location on the Playlist before you left is still there instead of going to the top of the playlist and also de-selecting your previous highlighted selection if you had one.
It’s very time consuming every time you come back to a playlist you have to scroll thru the playlist to find where you left off.
Thank you!
@Donn thanks for the suggestion! I have already shared this with the dev team for consideration.
There is a feature in Serato that allows you to locate your last song by pressing command + l. If we could do that as well that would be awesome
Big plus one for this please.
As a Voiceover user with no sight, it’s even more painful and time consuming to re-find the place in the playlist I was at, as can’t just visually scroll down easily.
Keeping the place in playlistst when leaving and returning would improve workflow tremendously.
You can also add the option that when user click on the running tracks in the deck screen (for example on the track title), it focus directly on these track into the playlist from where it was played.
When I switch view with pushing the jogwheel the main song browser will reset to the topmost song. This is annoying. It should snap back to what ever song is loaded at the moment or what ever song was selected before pushing the jogwheel. thanks!
Hi @Johan_Rosenberg, I’ve merged your topic with this existing one as they sound related. This has already been reported to the dev team. I’ll report back here when I have news. Thanks!
Hello, i’m on playlist A with a shortcut by BPM, I go to playlist B and back to playlist A, the library starts again from the top, in my case from the lowest BPM.
In Serato goes back to the last song selection and is very useful.
I don’t have to scroll again to find my last choice.
Can you add this please?
This is also part of the little things that need to be fixed as soon as possible it’s really annoying
A lot of DJs are switching from Serato to this app i believe they have to do better than Serato to fully convince DJs using Serato for years to switch to djay pro
Hi @Papagp, please use search before creating new topics. I have merged your new topic with this existing one.
I have passed this onto the dev team for further consideration. In the meantime, please use the blue Vote button at the top left of this page so we can track user demand for this feature. Thanks!
yes please i hope this gets implemented into the software soon its such a hady feature
Thanks for the additional feedback @Owe_Marley
Wow I see this feature has been spread across topics! Just using different wording but the core concept has been suggested for over 3 years.
I just saw my post was merged to bug reports so I’m going to support the suggestion /feature request posts as maybe that’ll get it across the quicker.
It’s one drawback of using DJP that makes it hard to recommend it to pro Dj’s honestly.
Thanks for continuing to push this topic @Mixfit. I’ll discuss this again with our engineering and dev teams.
Thanks for keeping on top of this ![]()
You’re welcome @Mixfit
I love the Locate feature, but can we tweak how it behaves?
Ideally, I want Locate to find the track wherever it appears across any playlist, without forcing me back to the exact original list. I want to stay in my current playlist and use Command + L to jump to the point in that list where that track appears.
