I noticed that odd-numbered loop lengths have just been added — see Add ability for polyrhythmic loop lengths (5 beat , 3 beat or 1.5 beat, etc) - #20 by Slak_Jaw
This is great to see, and I also noticed that you can divide loop lengths of 3, 5, 7, and 9 in half. For example you can set a loop length to a dotted half (3), and divide it into a dotted quarter (3/2) and keep dividing it all the way to 3/64.
I’d love to see a couple of extensions to this concept.
First is to bring this capability to the Looper effect, so you could do quantized “slip” style loops that are dotted-quarter, dotted-eighth, or triplet length. This is the main suggestion for this thread and something I’ve daydreamed about more than once.
Second would be an ability (behind a switch if needed) to allow the dotted notes / triplet lengths to be pre-selectable as a loop length without having to use loop in/out followed by division.
