I have tried to double-click on tracks several times but to load on any empty deck but has just not worked. I am using MacOS (2022) with Rane Performer. Please, could any one advise?
Hi @Hans_Mulleur, please do not post questions or issues like this in the general release notes as they can often get lost or missed. Plus they are difficult to discuss in a broad general topic. I’ve created a new topic for this discussion.
Please start by providing complete details for your setup:
Please also capture and share a short video of what you’re trying to achieve and how it is behaving differently than expected. Thanks!
My initial guess, based on your description is that you have the Double-click song in library to edit metadata enabled in the djay Settings>Advanced>Trackpad & Mouse. If so, please try unchecking this setting and testing again. I hope that helps!
Device Model (ex. 2020 iPad Air 4th Gen): 2022 MacBook Pro
Version of djay (ex. 5.1.3): 5.4
Hardware/controllers used (ex. Reloop Ready): Rane Performer
Hardware Firmware Version (ex. 2.7): Latest firmware
I am currently at work and do not have access to my dj equipment.
Thanks for the additional info @Hans_Mulleur. I’ll wait for your follow up later then…
Many thanks @Slak_Jaw I will check the settings as advised and feedback. Thank you very much!!
@Slak_Jaw thank you so much. I have followed your instructions and this is now sorted. Many thanks once more.
Perfect! You’re welcome @Hans_Mulleur
