Double Clicking any other Playlist/Search RESETS entire Automix Primary Cue
  • Macbook Pro*:
  • Monterey 121)*:
  • Version of djay 5.2
If I accidentally double click while trying to drag any items outside of my auto mix, the entire cue list I have created is erased and replaced with whatever folder I was looking into. Any way to prevent this such as a pop up that I have to confirm wanting to replace the entire automix set?
Hi @DJDust, thanks for the details about your setup and the issue. Can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
