loading from Dropbox means opening the file an d cutting the sound off DJAY so it can;t be done on the fly during a mix or a set. Djay would have to see Dropbox files in the iTunes Library or a new library.
Would like to add Google Drive here as a source.
Avantage of Goolge Drive is that it is way cheaper than Dropbox and has the possibility to share something as ‘Read-only’.
I am able to find tracks in dropbox using Djay 2 on my iphone by going to My Music and then My Files, but this doesn’t work that way on DJay Pro on my ipad for some reason. On the iPad with DJay Pro, I can only pull files from iCloud. Is there a setting I can adjust to correct this?
