Dropped Frames When Recording Video
  • Device model M1 Max Mac Studio (64GB Ram):
  • Version of operating system macOS Sequoia 15.5:
  • Version of djay 5.3.2:
Summary of the issue:
When I have a video loaded on 1 track and a local audio file loaded on the other track, I then sync them, and record as a video. When I am playing back this video, I am getting dropped frames like every 10 seconds or so. I never use to have this issue before. Also, I have went into FORCE QUIT and shut down everything except djay pro when recording the video. I have played back the video to make sure that was fine, and it is, the original video plays back just fine with no dropped frames. I am not sure if “dropped frames” is the correct way to describe the issue, what it looks like it’s doing is slightly slowing down for a second, then resumes normally.
Hi @Raymond_S, can you please upload a section of the video with the issue here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
