Reporting Audio Dropouts which can also be seen in the Waveform. But they are not in the file. Compare with RX7: original file versus recorded output from DjayPro.
The missing junk is re-filled only after restarting the App.
Updated V5.0.2
Updated V5.0.2
Moved from Main forum/ wrote already an email plus videos with audio on 14. of february. This is just a note.
Audio errors appear if I navigate by jumping through the waveform (bar). Additionally your software also shows them in the audio waveform visually as black lines!
These glitches in audio appears since v5.0.0.
macOS Sonoma, M1Pro MacBookPro 16“
everything updated, your software on 5.1.1.
Hi @SirHannes, thanks for the detailed information. To help me troubleshoot this with you, can you please provide additional details?
Please note that you can see the dropouts in the DjayPro waveform. They appear also there.
Hi @SirHannes, thanks for answering my questions.
Best
Thanks @SirHannes,
Please make sure that you name your attached video file as the following (ATTN: SLAK_JAW, DROPS IN AUDIO-COMMUNITY) so we can easily track it in our system.
Upload to dropbox is done.
