Dual layer cue system
Something missing from cue drumming is that the cues do dual layer on top of each other . Here is an example cue 1 is my kick and cue 2 is a snare .when cue drumming the snare can never play over the kick as cues stand right now but with a nice dual layer cue system then they would be able to allowing u to make some nice patterns turning dj pro cues system into a mpc if we want
Hi @CrossFade1200, thanks for the suggestion. Can you please clarify what you are after here and provide more details? Perhaps a video or some marked up screenshots? I want to make sure I understand this correctly and properly communicate it to our devs. Thanks!
My bad so I want to be able to play 2 cues at the same time when I’m cue drumming another way I can use it is I could cue a melody and a vocal steam cue at the same time
No problem. Thanks for clarifying @CrossFade1200. I’ll share this with our devs.
