Hi all.
I’ve got a Numark PTO1 scratch deck, Stokyo cutter external fader and a Serato timecode vinyl . Got app on iPad and adapter for iPad to connect usb … I’m guessing I will need a dvs sound card … would an old one work like rane sl2 work? I’m using app for scratching and beats
Thank you all
Hi @Green711, welcome to the Community!
- As the PT01 has line-level audio output (not phono output) you can use any iOS-compatible audio interface.
- I believe the RANE SL2 is not class compliant (needs drivers), so it won’t work on iOS.
- The Reloop Flux or Denon DJ DS1 are class compliant. Please note that there have been reports of latency issues when using the Reloop Flux. However, in most cases, turning Bluetooth off seems to solve this issue.
- You could also use something simpler / cheaper that just has a stereo audio input.
For a deeper discussion on the Reloop Flux, please refer to this topic: iPad Pro + Reloop Flux - #4 by Enricoiac.62
I hope that helps!
