DVS on iOS - is not good enough yet. FEB 2024 EDIT: Is Flawless
my i try the new euphonia dj mixer with djay pro with iphone 14 pro a alert flash driver not detected on the mixer but i arrive to configure in djay pro but seem to have a laggy dvs not precise and after 20 minutes approx the bpm change by it self !!! but with rekorbox dvs everything is perfect . i use brand new dvs vinyl from djay pro neuro mix buy last week to get shure i’m all up to date .
Is your iPad powered by Lightning connector or USB-C? How did you connect the Flux to your iPad?
Into iPad with USB C. The flux can either be bus powered, which runs the iPad down fairly quickly, or act as a powered hub - again via a usb c charger.
Hello everyone! I’m happy to report that we’ve made several DVS improvements in djay 5.3.
• Introducing THRU mode to play audio from regular vinyl
• Improved sync when scratching
• Improved adjusting of DVS tempo in small increments
• Improved tempo linking and fixed tempo linking issues
• Fixed auto-switch to REL sometimes not working
For the full 5.3 release notes, please refer to the topic below. Thanks!
Hi @Slak_Jaw , I came back to this thread to post a reply about the update and you’re here already!
Huge thanks to the devs for the DVS updates and to you for keeping on top of all the comments. More reasons to not return to Serato!
Welcome back @afursedon. Thanks for the positive feedback!
