DVS with Pioneer DJM-250 mk2
Your question:
I have a pioneer djm 250 Mo 2 and trying to set up dvs but the only thing I receive is
no signal check your RCA cable and make sure you have set up line/phono imput correctly
Can someone help me please ?
The djm 250 is not class compliant. It doesn’t work on iOS.
It requires drivers to work with Windows and MacOS.
Thanks for your prompt response. Can please tell me which drive I have to use ?
Hi @Thejazzlounge, welcome to the Community! As Wyley has indicated, the DJM-250 is not supported on iOS. Have you tried setting it up on macOS or Windows instead? Please download the latest macOS or Windows drivers from the Pioneer website for the DJM-250. Thanks!
Thanks for the message , I did update and it does see the turntable and managed to calibrate correctly, but when I load a track still hear the white nose coming from the dvs vinyl , do I need to do something in the setting befor be able to play with dvs now? Thanks
Hi again @Thejazzlounge. Sorry for the delayed response. I checked with our engineering team and unfortunately this hardware cannot be used for DVS because the audio input is locked unless a licensed app (Rekordbox) is open.
