I would like to be able to line up some tunes in the queue…be able to shuffle them around AND choose which table they load on…but having to go to the Automix section to access the queue is a bit frustrating…it would be nice if it were another button at the top or above auto mix…
The Queue can be accessed and edited/rearranged directly in the main music library in djay 2. You do not have to go through Automix.
Thank you, I just found that…I appreciate the feedback. Although having to use the EDIT button to do anything like delete a song or move it seems redundant…why not just drag it directly in the list and swipe to delete…?
Also, what is the behaviour when you select LOAD…does it just go to the deck not being currently used?
