I have an issue with the manual effect “Echo” on the Voice Stem. It does not completely fade out the voice, even when the D/W knob is turned fully to “W”.
I would expect it to fully echo out the voice, similar to how the Instant Effect “Echo Voice Out” works. As it is, this effect is not very usable for me.
Hi @DJ_Big_Blender, this is expected behaviour with the regular Echo FX. This applies an Echo effect to the Vocal not an Echo Out effect. Try using the Echo Out or Echo Out+ FX instead of the regular Echo.
Hi again @DJ_Big_Blender, can you please confirm if the above suggestion solved your issue? Thanks!
Yes it did. Thanks a lot!
Perfect! You’re welcome @DJ_Big_Blender
