Echo Out Effect does not work
  • Device model: Surface Laptop 3
  • Version of operating system: Win 11
  • Version of djay: 5.1.7887.0
  • Hardware/controllers used: Pioneer DDJ-400
Your question:
Hello,
I used Djay Pro on my MacBook for two years and worked a lot with the Echo Out Effect. Now I’ve switched to Surface and downloaded the latest version of Djay Pro and unfortunately the Out effects don’t work properly: both Echo Out and Reverb Out etc. execute the effect, but the track doesn’t end but continues to play a little quieter. Can you please help me?
Thank you
Try adjusting the effect wet and dry or effect depth knobs.
No problem off topic post removed. :+1: :person_shrugging:
Hi @Milad86, as @SamJam described, please make sure the D/W knob for the Echo Out FX is set all the way to W.
Thank you all, that worked!
You’re welcome @Milad86. Thanks for the follow up.
