The voice Echo Out option is really missing. Me and my friends used it a lot with Serato.
It is definitely a smarter way to fade a voice.
You can map it yourself to instant effects. You do lose out on some instant effects but if you use echo out a lot on vocals then it’s worth doing. You can do other cool neural effects as well with drums.
You should review Serato voice out effects
Have you tried the echo and juggler vocal stem effect in Djay?
I just don’t really like serato. Not my jam.
