Wouldn’t mind a edit section In Djay pro where u can shorten tracks and re edit while being able to use stems as well in the edit section ,like u can in rekordbox and Serato studio
Thanks for the suggestion @Ellisparty. I’ll pass this onto the dev team for consideration. In the meantime, I feel like you could simply use the Record function in djay Pro along with the Neural Mix tools to record an “edit” of the song to achieve the results you want.
This is how I make all my re edits
Me too. Quick, easy and all the same tools you’re used to while DJing.
