I would be fine doing all my meta data editing in Djay Pro, but there doesn’t appear to be a way to edit the album art.
Therefore when getting tracks from a record pool or similar, I’ll tend to update the album art to match the track in iTunes and then make any meta data changes there. However depending on when I do that I can trigger a bug in the software.
So, unless I’m missing something, it’d be great if the software allowed the editing of the album art directly in the software.
Thanks for another suggestion @andybarnes. I have forwarded this to the dev team for consideration.
Second this suggestion! Would be great to be able to do all metadata editing within djay pro.
Side note: if not, would be good if djay pro “refreshed” the metadata upon loading/reanalysing if it has been changed in another software. I’ve noticed I need to fully close djay pro first and the new metadata will show on the reload.
Thanks for the additional thoughts @jaysnbrwn. I’ll let the team know…
