Is there any way to edit dynamic beat grids? Point and click (and perhaps eventually something controller-based) would be great and intuitive to me. Some tracks that can benefit from dynamic beatgrid aren’t analyzed properly and it would be great to both keep the analyzed flexible beatgrid and edit them, but I can’t. Am I missing something, or could this be a feature?
Thank you and happy holidays!
Djay Pro 5.2.6
Sequoia 15.2
Your question:
Hi @chuckles, yes you can edit the Fluid Beatgrids. Most likely you will want to add additional Anchor Points.
For more info, please refer to the linked FAQ: https://help.algoriddim.com/hc/en-us/articles/11611322144284-How-do-I-use-Fluid-Beatgrid-in-djay-Pro-for-Mac
Thank you. This is helpful, but feels very non-intuitive. Still a bit clunky compared to what I’m used to in Serato, and I’d love to see this be something that we could edit and manipulate with midi and jogwheels. If we have to use a point and click interface, it would be great to be able to just hit an “edit beatgrid” button and drag the beatgrid itself to where it ought to be right on the waveform. Especially since those yellow anchor points look oh-so-draggable.
You’re welcome. Thanks for the additional feedback @chuckles
