Effect on/off
Hi. Is there an option to make the effect on/off less abrupt? Current functionality appears to be as soon as you turn an effect off it instantly disappears. This isn’t great when you are using effects with a tail (eg. Delay, reverb, etc) where you want it to fade gradually to nothing, at the end of a breakdown for instance. If I want the effect off immediately I can turn the dry/wet fully dry.
I thought enabling post fader in settings would do this, but apparently not. Is there another option I’m missing?
Thanks for sharing the additional info. Enabling post-fader FX means that effects like “Echo” or “Reverb” will still play their tail after you mute a deck for example (conversely, if post-fader is off in settings then the effect will be muted simultaneously with the deck).
To smoothly fade in an effect, the best option is to move the wet / dry knob all the way to the left (“dry” so no effect is heard), enable the FX via the ON button, then gradually move the wet / dry knob to fade in the effect.
I hope this helps. Let me know if you need any further suggestions.
Thanks for clarifying. I assume your preferred solution would be to fade the effect out automatically (I’ll pass that on to the team). As a workaround, when turning the effect off you could do the steps above in reverse order, i.e. gradually move the wet/dry knob from wet to dry, then tap the off button for the effect.
Let me know if this workaround helps.
Hi Lukas,
I’m using the latest version (3.0.8) with the Pro subscription on an iPad Pro.
Thx.
I’m sorry, but that doesn’t answer the original question, which relates to switching an effect off, not switching it on.
Hi. Yes, I understand that…it’s what I have to do now. It’s just odd functionality that I haven’t seen before.
Hi MP,
Which djay version and which device are you using?
Thank you for your reply.
