Hey,
I really liked the option in Traktor to set 3 effects above left deck and 3 effects above right deck.
Looks similar now in Djay Pro but I am missing the option to use the right 3 effects for the left deck. So in Traktor you end up with 6 effects you can use on both decks. In Djay Pro I need to set up the same 3 effects for both decks just to be able to have 3 in total but taking up space for 6 effects . It’s lost space in my opinion.
Would be awesome to have 6 effects and choose which deck should get the effects like in Traktor.
In the screenshot you see 4 decks, 3 effects per deck is in total 12 effects you can use when playing with 4 decks . 2 decks = 6 effects
