eFx remote trigger app for iPad running Djay Pro Mac
Hello, finally successfully setup djay pro (MAC) with DDJ-T1 Pioneer … also install the ipad version … and here is where my question? … Have thought any option that transforms the pro version djay ( iPAD) on a remote application for the mac app?, some special to handle the sound effects (XY), video and visual transitions, samples and more from the ipad, via (wifi, adhoc or usb), something like the VDJ8 remote or Serato app … … with the difference that djay has better, plenty and excellent sound effects, thanks!
hope like the idea… here’s a quick pic
thanks brothers :slight_smile: really really appreciated
hey brother. i could noto reach to file for link has expired. is it possible you to send to my email adress? if yes please kindly type artizkeci@outlook.com
have nice life… thanks
Hi… this is the mapper I use, (Mac)
http://www45.zippyshare.com/v/8owDlBG…
enjoy
Hi Jesus,
would you be kind enough to send me your config file for DDJ-T1 please…??
regards,
Pada
