Hello,
Is there a way to make a function where you automatically eject Tidal songs in both decks and replace with another “loaded” song from say, SoundCloud or Bestsource to work around Tidal’s new policy? Maybe even an echo out
Hello,
This is not possible within djay Pro, but there are services like TuneMyMusic that will help you to transfer your playlists between different streaming services. After completing the process, you could simply log out of the old streaming service in djay and use the new one instead.
I know you can’t play both, but if you eject and auto replace, is that still “streaming together,” which is against there rules? That’s my question.
You can play tidal now with another steaming service. They changed that so now you can.
