Does DJAY have an “eject lock” which means you can’t purge or remove files?
Hi @Alexseyn_Rodrigues, I’m not sure what you mean by “eject lock”. Can you share an example from other DJ software to help clarify?
We do have a setting called “Protect Active Deck” which prevents you from accidentally loading another song onto the master deck.
Even if the original poster is talking about a different problem, it’s true that “Protect active deck” mode does not stop a track on the active deck from being ejected (iPad, Djay 5.3.2). I’ve created separate topic for this issue.
Hello! This is exactly what I needed.
Excellent. Glad that’s what you were looking for.
