el capitan with djay pro and reloop beatpad
has anybody done the update to El Capitan?
does everything works fine with djay pro and reloop beatpad (1 and 2) or Wego (2 and 3)
I use the 4 controllers,
thanks
I use the wego 3 and, so far, no issues found.
djay Pro is completely supported by El Capitan. The only thing you should check before updating are the drivers of your controllers.
But both Beatpads and the WeGo 2 and 3 are supported by El Capitan as well.
There should be no compatibility problem at all.
Cheers.
iv used djay pro with beat pad 2 and it works great. Hope that helps.
thanks!
I’ll try
