Up to 5.2.8 it was possible in landscape mode to access the match feature by pressing shift + library rotary.
Bizarrely this has been identified as a bug and removed from subsequent updates.
The option remains within portrait mode on iPad and both orientations on the iPhone due to library layouts.
If it can’t be restored could we please have a midi command to access the match panel and navigate through it when in landscape.
It’s already hard enough work dabbing through hot cues , loops, effects etc with one’s finger without having to do this as extra.
Hi @daniel_curley, I am already discussing this with the engineering and dev teams from your other topic. I’ll let you know here when I have more news. Thanks!
Hey @Slak_Jaw.
I’m really missing this feature and not really loving portrait mode.
Thinking of reverting back to 5.2.4 until something happens.
Is hardware mode available on 5.2.4?
Hi @daniel_curley, I’m pretty sure 5.2.4 has Hardware Mode, but let me just double check with engineering before you recover your device with an earlier backup. Thanks!
EDIT: I can confirm that Hardware Mode was added in djay 5.2.0 so you should be good.
Thank you. Much appreciated
You’re very welcome @daniel_curley
