Enable drag and drop for Sample Assignment
Is it possible to improve the general sample assignment in Djay pro.
In Serato you can drag an drop the samples on the slots.
In Djay pro the sample are kind of hard to handle.
Drag and Drop would be a better way to assign the samples.
Maybe you can implement a drag and drop how you handle samples.
The interface where you can choose the samples are kind of old fashioned.
You need to search the samples from the folder on the hdd. Then search again in a long list in Djay pro with the name of the sample to assign it to the slot.
This is complicated.
Thanks for the suggestion @Sneakdiver. Sounds like a good idea. Can you please share a short video showing how this works in Serato?
I’ll share this with the devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
This is how it works:
Serato pro Sample assignment
Thanks for the video @Sneakdiver - this clarifies things a lot!
