Enable Meta-Quest DJ mic talkover
The MetaQuest Hmd has an amazing built in microphone that virtually eliminates any sound seeping thru, except the wearer’s voice. This would make as an excellent DJ mic talkover.
If you can include a mic fader in the console —that would be amazing.
P.s. the MetaQuest headset also allows usb external mic input
Overall, it truly is an all-in-one futuristic DJ console and record crate (if you guys will fix the local ‘black record artwork’ issue)
Cheers
Thanks for the suggestion @dirrogate. Good idea. I’ll pass this onto the devs for consideration.
