Enable Neural Mix multi-waveforms on Mac, 4 Deck Mode like iPhone
Your question:
Why is it possible to split waveforms on iphone 14 but not on Mac mini m1??
Hi @DjSille, can you please clarify? Are you talking about the Neural Mix Tracks 4 waveform display in 2 Deck Pro Mode? If not, can you please share some screenshots to help clarify? Thanks!
This is iphone
This is iMac, Here you can see that I can’t split the waves in neural mix tracks
Thanks for the photos @DjSille - this helps to clarify things. I see what you mean now. So NM multi-waveforms in 4 Deck Mode. This is the same on iPad actually. Let me check with the team and get back to you.
Hi again @DjSille, I spoke with our development team and this was done intentionally on Mac to prevent things from looking too busy or complex in 4 Deck Mode. However, they are going to revisit this and consider implementing it in an upcoming release. Thanks again for pointing it out! I’ll report back here when I have more news.
I’ve also changed this topic from a Question to a Suggestion so that other users can upvote the idea.
+1!!
I am a dedicated Traktor user, but if this comes into an upcoming release, I might even think about swithing alltogether to Djay.
If you could also add the possibility to filter each stem (instead of just volume), you got me and I will use Djay instead of Traktor.
Thanks!!
Hi @Wally_P, welcome to the Community! Thanks for the feedback.
You can already apply Filters to each STEM using the Manual Filter FX and FX Routing options.
Thanks for the reply!
I was aware of that, but that means I use 2 effect slots per channel.
In Traktor there is an option to apply the HP/LP Filter to each of the stems. A function that I use a lot, since I tend to filter my stems before I sent them to the FX units.
You’re welcome @Wally_P. Thanks for the additional feedback.
